Results 1 to 10 of 12
Thread: popping?
    Jan 2013
    15
    Default popping?
    I'm running a ranger 305g with 1700 hours on it. When welding it is popping and spitting more than normal. Tried different heat and compared head to head with other welders using the same kinds of rods and we can't seem to get it to stop. Does anyone have any ideas as to what causes big popping and spitting? When i say that I mean more than normal of course.
    Aug 2004
    Milan Michigan
    1,806
    Valves out of adjustment or maybe a dropped valve, broken keeper.
    alabama
    750
    I think he means in the arc is having issues. Brendan can you specify as to which one it is?
    2, XMT's 350 cc/cv
    1, BOBCAT 250
    1, TRAILBLAZER 302
    1, MILLER DVI
    1, PASSPORT PLUS
    1, DYNASTY 200 DX
    1, MAXSTAR 150 STL
    1, HOBART CHAMP
    1, HF-251 BOX
    1, S-74d
    1, S-75DXA
    2, 12-RC SUITCASES
    2, 30 A spoolguns
    Jan 2013
    15
    Default popping?
    Sorry, arc yes.
    Cave Creek Az
    1,046
    Got the right polarity, process switch to the right one (cc/cv)?
    Jan 2013
    15
    Default popping?
    Yup. The other guy who was trouble shooting and trying to figure it out with me has welded for about 19 years. There is a truremote wireless remote on it thinking something may be up with that
    Jan 2013
    15
    Default popping?
    It's almost similar to the popping and spitting of arc blow but arc blow is not the case.
    Jan 2013
    15
    Default popping?
    Sorry for all the posts. I'm posting as I go. I think another way to describe it is that it is popping and spitting instead of sizzling (frying bacon sound) if that makes sense
    Oct 2005
    North Central Indiana
    782
    Could the metal be magnetized or could splatter guard have been sprayed on the steel?
    Is the metal new or from a salvage yard where it could have gotten something dumped, spilled or sprayed on it and cleaned off ?
    Sounds like the steel is the problem ifen everyone else is using the same wire and your machine works on other jobs......
    alabama
    750
    I would first start by checking to make sure the rpm is correct. Below is a link per Cruizers specifications.
    http://www.millerwelds.com/resources...ighlight=meter
    2, XMT's 350 cc/cv
    1, BOBCAT 250
    1, TRAILBLAZER 302
    1, MILLER DVI
    1, PASSPORT PLUS
    1, DYNASTY 200 DX
    1, MAXSTAR 150 STL
    1, HOBART CHAMP
    1, HF-251 BOX
    1, S-74d
    1, S-75DXA
    2, 12-RC SUITCASES
    2, 30 A spoolguns
