Results 1 to 5 of 5
Hybrid View
    Apr 2009
    362
    Default Millermatic 350P Gas Issue
    Got a 350P with a Python push/pull gun and it seems to have a gas delivery issue. I have to have the flowmeter cranked to max in order to get proper shielding. At 25cfh of argon, it very rarely produces a nice weld. I have tried a different flowmeter and the problem persists. Is this a common problem?
    Oct 2011
    10
    Default 350p gas flow
    Any problem with your 400 gun on steel ?. That should tell you where the
    problem lies.
    B.J.
    Aug 2010
    Los Angeles
    1,170
    I have never had the problem myself, but how do you know that 25 cfh is getting to the nozzle?
    One thing to check is try the flow without connected to the machine to see if there is a difference.
    Myself I use a portable flowmeter from netwelding.com to actually verify the flow at the nozzle.
    You say argon, so I assume you are welding alum?
    Miller Dynasty700DX
    3 ea. Miller Dynasty350DX
    Miller Dynasty200DX
    ThermalArc 400 GTSW
    MillerMatic350P
    MillerMatic200 with spoolgun
    MKCobraMig260
    Lincoln SP-170T
    Linde UCC305 (sold 2011)
    Hypertherm 1250
    Hypertherm 800
    PlasmaCam CNC cutter
    Fadal Toolroom CNC Mill
    SiberHegner CNC Mill
    2 ea. Bridgeport
    LeBlond 15" Lathe
    Haberle 18" Cold Saw
    Doringer 14" Cold Saw
    Apr 2009
    362
    Quote Originally Posted by bridgeportBJ View Post
    problem lies.
    B.J.
    Good point. I have a separate gun for steel, so that will determine whether the problem is in the machine, or my push/pull gun.
    Quote Originally Posted by shovelon View Post
    Yup, welding aluminum. I do a lot of tigging, and often I put the torch up to my cheek to verify argon flow. When I do that with this Python gun, there is no comparison that its much less than I'm use to feeling.
    Oct 2004
    Edmonton, Alberta
    8,206
    OK, easy fix, cause I just know you used teflon tape on the brass fittings. Remove the gas hose to machine connector, inside you'll see a little screen. is it full of tap, or other stuff, probably, clean it and no more tape,,,,
