Results 1 to 7 of 7
    Apr 2013
    Default gun shy with aluminum tig
    Hello, I'm new to welding. Actually became my task in work. A little scared with tig aluminum. O&M scared me with warnings. Have stick welded and flux mig ( not a lot) but want to experiment. Is it safe
    Cave Creek Az
    1,040
    It is as safe as any other process, unless you have a pace maker or some other med device that prohibits it.
    Find the educational videos on this site. Andy does a great job in them, and you will be much more comfortable after learning from them.
    Apr 2013
    Thanks!!! I will give it a go
    May 2013
    11
    Default Safe enough
    I only post this because today, well protected, gloves, shop overalls, rubber shoes, DC steel welding I got a small shock when the rod got stuck. These gloves are brand new, less than one 80 lbs tank old. I haven't studied enough to go into anymore detail or try to speculate as why, but it was a shocker. Figuratively, and literally. But I think the shock was only like 40v. Is that sound right? I am really sure I felt it. That won't stop me. Maybe I'll just chalk it up to a learning lesson. Why am I getting my rod stuck? Backing off of the torch? Adding too much, too close to the middle of the puddle instead of the leading edge of the puddle?
    Montana, USA
    236
    The only times I have gotten shocked was when I failed to attach the ground clamp, or when the clamp did not provide an adequate electrical contact to the table or piece.
    Perhaps you are not sticking the rod into the puddle to melt it. I suspect the rod is melting when it enters the plasma zone, instead of the puddle. Then, when it touches the piece the "bubble" on the end cools immediately, and sticks.
    Jul 2010
    378
    The HF can give you a "shock" if you're not careful, but even though the voltage of the HF is high, the amperage is microscopic, so it can't really "hurt" you in any kind of dangerous way. (HF can mess with pacemakers, though.)
    1,890
    Nothing to be concerned about. Any welding process can be unsafe. Use common sense & cover up.
    Shocks are just part of the territory especially with hf. Not saying it happens all the time but occasionally it will.
