Results 11 to 20 of 25
    Dec 2008
    Arizona
    812
    If you're worried about cracking, use epoxy. Building code here only accepts that for load bearing walls if the anchors aren't placed before the pour.
    Miller Syncrowave 200
    Homemade Water Cooler
    130XP MIG
    Spectrum 375
    60 year old Logan Lathe
    Select Machine and Tool Mill
    Wa
    621
    Nocheapgas, that's already been discussed in his previous thread, wedge anchor is his best bet.
    Oct 2005
    North Central Indiana
    782
    The picture shows how I used the crack joint to slip some 3/8 plates down into to the concrete 2 1/2" to keep the table from moving when cranking on something in the vise. The plates held the weight of the generator but the opposite side of the table lifted up about six inches.
    Table with the crane
    Wa
    621
    Are you going to use anchors in addition to those? Or is it stable enough now?
    Oct 2005
    782
    Mr. C I'm going to put an anchor on each leg opposite the crane. If that isn't enough then I'll put two on the crane side. The table only came up about 6" lifting the generator on the table so I'm thinking two on the far side will be enough. The generator and the Snapper's deck will be about the heaviest things I lift on the table.
    May 2013
    East Tenn
    148
    Default Calling meltedmetal and Cgotto6
    We build pre-fab metal buildings and have been using redheads/hilti's/duo-fast anchors for the last 4-5 years. We used to lay out all the anchor bolts before the concrete and install them while the Crete was curing. Now it's just drill and go. Only two problems we have are putting them in when the Crete is still green or use the wrong size bit. Actually just used some yesterday attaching a deck to a concrete pad. Works like a charm. Hope all goes well with your installation.
    Oct 2005
    782
    Quote Originally Posted by Precision View Post
    Very nice of you to wish me good luck Precision, thanks
    Dec 2012
    Sweetwater, TX
    201
    I've been reading this thread from time to time since I have to install some anchors for something.
    What is your definition of when the concrete is still green? Like days old, weeks, months, a few years?
    The shop building I bought has a slab about a year old and it already has a LONG crack running down the middle. It only has a 3 1/2" slab probably. Guess that is the quality of work people do around here though. I would be blazing hot at the company who poured it if they had poured it for me.
    Wa
    621
    Green to me is within a month or so, but you can really do anything with it within 3-5 days. A year is more than adequate time for anything.
    May 2013
    East Tenn
    148
    Concrete actually takes many years to"fully"dry as it sucks moisture up from the ground. That's why you have to vapor barrier if you put hardwood floor or something like that on top of concrete. "Green" is within 24-48 hrs to 5 days. Depends if you add accelerants to it for a faster cure. We mainly use a fiberglass reinforced crete at 6" with rebar and wire reinforcements. A lot of guys like the .22 Hilti's and duo fasts that shoot the fastener into the floor. I myself do not. It only takes a min orso extra and if the shot doesn't hold you end up using a tapcon or red head anyway so why not use em from the start. "If it ain't broke".
