Page 2 of 2 FirstFirst 12
Results 11 to 14 of 14
    Oct 2005
    North Central Indiana
    782
    Quote Originally Posted by snowbird View Post
    a chart found on a blasting site.
    snowbird when I click on the link I get a message that windows photo viewer can't read the file????? It happens a lot I don't know how to fix it...
    Oct 2005
    782
    I tried everything, either I get moisture or their isn't enough product. My nozzle's orfice is a 3/32, I been thinking about buying a bigger hose for more air but with the setup I have, pressure backs up into the tank because the volume is so much greater than can escape out the nozzle. If I could try a water type blaster before I had to buy one I would try it out.
    I'm having a few bad days, the family is pissing me off. I think I need to get drunk and go swimming naked.
    Dec 2011
    385
    It is a pdf file inside a zip file. I tried to copy it as a pdf and upload it directly but I get a message that it is larger than the web site will allow for this type of file. Maybe snowbird can post a link to where he found it.----Meltedmetal
  4. #14
    Mar 2011
    st-eustache qc.canada
    191
    Default this one should be redable.
    Sorry for the delay, wife kept me busy today ;o)
    edit.can't fix the redable for readable...no wonder why i post pdf's
