Results 1 to 1 of 1
Hybrid View
    Feb 2013
    6
    Default Millermatic 250 not working
    millermatic 250 the problem i'm not getting voltage to wire drive motor. there is a red lite on circuit board that comes on when trigger is pressed but goes right out. there does not seem to be voltage at the positive and negative lead lugs. should these be energized when trigger is pressed. Wondering if anyone has had this problem.
