Results 1 to 3 of 3
Thread: Tig cup sizes.
    116
    Default Tig cup sizes.
    What are the rules regarding electrode size when matching with cup size.
    I have found nothing written in a Miller book that explains this subject.
    Aug 2010
    1,170
    Quote Originally Posted by jmpgino View Post
    It's not about electrode size, rather than weld size. The bigger/wider the weld, the more coverage you need. Travel speed is a factor too. Fast travel can leave molten puddle uncovered, so an increase in trailing gas is desired. A bigger cup can help.
    Miller Dynasty700DX
    3 ea. Miller Dynasty350DX
    Miller Dynasty200DX
    ThermalArc 400 GTSW
    MillerMatic350P
    MillerMatic200 with spoolgun
    MKCobraMig260
    Lincoln SP-170T
    Linde UCC305 (sold 2011)
    Hypertherm 1250
    Hypertherm 800
    PlasmaCam CNC cutter
    Fadal Toolroom CNC Mill
    SiberHegner CNC Mill
    2 ea. Bridgeport
    LeBlond 15" Lathe
    Haberle 18" Cold Saw
    Doringer 14" Cold Saw
    Per the miller TIG handbook, page 61:
    The inside diameter of the gas cup should be at least threetimes the tungsten diameter to provide adequate shieldinggas coverage. For example, if the tungsten is 1/16" in diameter,the gas cup should be a minimum of 3/16" diameter.Figure 8.2 is an example of gas cup size and torch position.
    http://www.millerwelds.com/resources/TIGhandbook/
    And shovelon's got it right for how large of a cup to go with.
