Results 1 to 8 of 8
Hybrid View
    Default difference between pillar drill and mag drill
    Is there a difference? Can you use normal drill bits on a mag drill?
    Salem ,Ohio
    3,936
    Cool
    Yes you can. There should be an adaptor for a number 3 MT and a drill chuck...Bob
    Which would you recommend? I need it mainly for drilling 25/26mm holes.
    Add Content
    Nov 2012
    Granville, ohio
    14
    I have used mag drills with regular chucks that don't take a morse taper bit, and also a hougen with the rotabroach type bits. I personally love the hougen drill, very lightweight and clean holes. Costly to buy upfront though
    Salem ,Ohio
    3,936
    Cool
    Quote Originally Posted by k3500crane View Post
    I 2nd the Hougen drill for what you are doing...Bob
    That's great, thanks very much.
    Oct 2005
    North Central Indiana
    782
    I've had good luck with my CSunitec mag drill and cutters, I would buy them again. http://www.csunitec.com/portable-magnetic-drills/
