    May 2013
    SW Missouri
    13
    Default Syncro 250- Missing gas valve
    My "new" find is missing the gas valve assembly
    Best place to find replacement? $150 + shipping is disappointing.
    Tested- stick, all polaritys-OK. High freq-OK.
    Called Miller, confirmed part #174-036.
    Thanks,
    Mike
    Long time lurker, 1st post
    Jul 2010
    Four Flags city
    304
    May 2013
    SW Missouri
    13
    Default Is 10 watt solenoid OK
    I have another Deltrol valve- identical but its 10 watts.
    Will it work?
    Mike
    May 2013
    SW Missouri
    13
    Default I think its resolved
    Ordered 2 separate pieces from miller 4 less-
    valve/solenoid- 035601 $65
    fittings- 010296 $17
    Miller tech laughed when I said those 2 assembled were $125
    Thanks to Big Mike!
