Page 2 of 2 FirstFirst 12
Results 11 to 17 of 17
    Dec 2011
    420
    I agree with sberry on this. Except for small amounts trapped in rust or scale on the surface the steel, unless it is porous, steel has no water in it. Steel is produced at upwards of 2500 degrees and no water lives there. The condition you observe is caused by moisture in the warm air of your torch condensing in the colder air and on the colder surface of the steel. The dew point in your flame and in the surrounding air are different. We see this often in our work where we pour molten metal into metal moulds. We always preheat to eliminate the possibility of moisture as the moulds are iron and they rust which can trap moisture on the surface. Failure to preheat can result in a steam driven explosion that can give the worker a faceful of molten metal. Not a fun day, been there done that and don't want to try it again.---Meltedmetal
    Oct 2005
    North Central Indiana
    782
    You know the more I'm wrong here the smarter I get. Thanks for setting me straight MM.
    I'm not talking about moisture in the steel.... but on the surface in the pours.
    Apr 2008
    254
    tackit
    I think thats correct. Part of preheating is about driving off residual moisture.
    Thanks for all the replies!
    One thing not answered which I would still like to know is how you all handle large spools of wire that last for more than a couple weeks? Isnt rust a problem in the summer?
  4. #14
    Oct 2005
    782
    Quote Originally Posted by HayFarmer View Post
    tackit
    Where I live winter going into spring makes tons of moisture, it puts a light coat of rust on all steel that's not been oiled or chromed. Summer here is pretty dry.... never have problems with rust during summer months..
  5. #15
    Apr 2012
    Western Pa.
    298
    Default mobile welding and low H rods
    Some wire comes with a special moisture resistant or absorbent paper over wire & inside a sealed plastic bag. I save the paper (keep in a zip lock bag) when take off a roll of wire even if it didn't come with one, I place paper over wire (it's directional) then put in a big zip lock bag or put in original bag & seal with tape.
    Another trick is to save the little moisture pacs or paper that come in parts or buy them & do the same. Keeps moisture off wire wile not in use.
    I also keep in a room on shelf off floor.
    Another tip is to keep shop at constant temp, doesn't need to be warm just keep from drastic temp changes. I hv in floor heat & keep it at 59-60 deg. year round even spring & fall, keeps temp from dropping on cool nights. Helps keep rust on metal and also equipment at mim.
    Metal oxidizes and that's kinda what rust is after time. It's good to read up on & understand as it relates to metal.
    If u do any blacksmith work it starts as soon as u pull a piece of metal out of forge. U can hv scale by the time u hit the anvil, it is by far not your friend especially if u ever try & forge weld.
    Hope it helps.
  6. #16
    Apr 2008
    254
    I was having a big problem w/ rust esp in the spring & summer when it was very hot/ humid. I couldnt take the wire back into the shop (below ground) b/c the large change in temp would cause condensation. I also couldnt leave it outside b/c at night condensation would be a problem. Even bringing into an ACed house wasnt good enough bc of condensation. I finally gave up and just lived w/ a small amt of rust. If I had critical welds Id use stick. Does anyone else run into this?
  7. #17
    Quote Originally Posted by tackit:307652
    I keep mine in these rod holder and have not had any problems. If moisture was was super critical I would think you would have to get the moisture out of the steel you're welding on too. http://www.rodguard.net/
    I use a similar type container with some small desiccant packs stuffed in.
    Miller 211 MVP
    Hobart StickMate LX 235
    Lincoln AC 225
    CutMaster 42
