Results 1 to 10 of 17
    Apr 2008
    254
    Default mobile welding and low H rods
    Im drawing a blank on this but the answer has to be simple...for mobile welders how do you keep your supply of low H rods hot? Yes, I know w/ a rod oven but how is it powered in the field?
    ETA: In fact do you keep your low H wire hot between jobs/overnight? This would serve 2 purposes...maintaining the low H characteristics and preventing rust.
    1,897
    Since I am not doing code work they lay in the box until used. No rod oven. FYI unless you buy the hermetically sealed containers they are already exposed. The cardboard or plastic container does not seal. I would imagine for what your using them for no rod oven needed.
    3,946
    No oven for me either. I like how they weld and always make it my first choice...Bob
    Simple answer would be a small rod oven I've seen guys with them the smallest one I've seen is slightly bigger than a 50lbs rod can so I assume it can hold the whole 50lbs. Where ever they park there rig is probably where the plug the oven in when they are not on a job and during a job just plug it into whatever power source they have
    Sep 2012
    seaford de
    406
    I use a Lincoln 10# oven. Plugs into my welder, it doesn't pull many amps. I also keep the rest of the 50# can in sealed rod tubes
    Jan 2012
    Marsden, sk. Canada
    29
    if you are on a larger job, there is quite often a 50 or 100lb oven that is left on all the time and you transfer rod to your smaller 10lb oven as you need.
    Jul 2012
    Liberty, Mo.
    64
    If I need to weld something that critical then I will buy them for that job usually in smaller containers. So it's not one big thing that's been "opened". That said, I have leftover junk rod all over my garage bought in garage sales, past jobs etc... I don't know off the top of my head but there is "allegedly" a way to recondition LH rod in your home oven if its not in too bad shape (ruined flux, rusted etc....). I'm no expert though.
    Oct 2005
    North Central Indiana
    782
    I keep mine in these rod holder and have not had any problems. If moisture was was super critical I would think you would have to get the moisture out of the steel you're welding on too. http://www.rodguard.net/
    4,446
    There is no moisture in the steel.
    Oct 2005
    782
    Then why does steel rust?
    If I'm short circuit welding on something and it's a cold and dank day I take my torch and warm it up, you can see the waves of moisture leaving the steel.
