Page 1 of 4 1234 LastLast
Results 1 to 10 of 32
Thread: diesel vs gas
    Jan 2012
    Marsden, sk. Canada
    29
    Default diesel vs gas
    thinking about switching my rig over to gas,truck and welder. i currently own a pro 300 cat. I am interested about the trailblazer 325, does anyone know if the new ones coming off the production line have all the bugs worked out yet?
    Default diesel over to gas
    Hey G.blackbeard what is it exactly your wanting to achieve by switching over? That pro 300 really gets amazing fuel economy, and there really isn't a better machine in its class. Many of the old pipeliners have switched over to these out here in the patch.
    Jan 2012
    Marsden, sk. Canada
    29
    i am tired of the maintenance costs associated with diesels. i want a new truck, but cant swallow the $10,000 more for the diesel motor/tranny, then spend up to 10 cents/litre more for diesel fuel. Does not seem to make much sense. I was thinking about the 325 simply so both units run the same type of fuel.
    Wa
    602
    10c/gal more is cheaper than the gas mileage difference to an equivalent class gas rig. Even more so the larger truck, or toting around heavy loads.
    Oswego IL
    691
    Default not always the case.
    The gas verse diesel debate will never end, but do the math and diesel is not cheaper. First take a f450 chassis, v10 vs diesel. V10 will get 10 to 12 on the highway, 8 to 9 in the city. Diesel will do 8 to 10 in the city and 12 to 14 on the highway. Now keep in mind if the truck idles at all regen will kill a diesel in fuel economy. Also the diesel maintance costs are much higher, ie 200 doller oil changes, 50 to 100 doller fuel filters, and if anything fails on the diesel expect to pay huge bills. In my mind a new diesel should be sold right before the 100k mark or when warranty ends. Fixing these new diesels is brutally expensive. Now take a v10 simple, only thing which fails on them are coils, exhaust manifold studs, and an oil change is $40.
    Kevin
    XMT 304
    Miller Spectrum 625
    Miller 30a spool gun
    S22a
    Miller Legend 302
    Lincoln LN25
    Jan 2012
    Marsden, sk. Canada
    29
    i just did injectors in my 6.0l and it was around $4,000. that is just shy of half the price of the diesel option on a new truck. What r 8 new sparkplugs worth?lots of guys i know buy new diesels then spend up to $2000 just so they run properly and get more than 10mpg.
    Apr 2006
    TAXACHUSSETTS
    1,489
    Quote Originally Posted by Tryagn5 View Post
    Kevin
    200 dollar oil change???I have 2 diesels oil is 14bucks a gal. x4=56 bucks.And a filter for my 7.3 is 10 bucks.the 6.0 is$25 bucks.Your off buy a good 100 bucks do the MATH!
    BB402D
    TB300D
    DIMENSION652
    MM250X
    MAXSTAR140
    HT/PWR-MAX1250 PLASMA
    Apr 2006
    TAXACHUSSETTS
    1,489
    If you can,t fix your own truck then yes,they are expensive.I can fix 99% of my own repairs myself but i was raised in a auto shop dad was a mechanic owned his own shop 35yrs.Was a tranny rebuilder,so i was born to turn wrenches.No dad can,t weld and i cant rebuild transmissions.
    BB402D
    TB300D
    DIMENSION652
    MM250X
    MAXSTAR140
    Jan 2012
    Marsden, sk. Canada
    29
    up here in canada, 14l of synthetic oil and filter is around $160. $180 at oil change pplace and i dont have to dispose old oil.
    Wa
    602
    Kevin
    Just about everything you just stated I have had exact opposite experiences. That's just me though, and I am not toting around a fully loaded service rig. My mason who is hauling pallets of block constantly just told me he is saving over $500 a month in gas over his old gas 450 with his new 550's which are diesels. Never heard of a large gas rig getting better than 10mpg under any condition other than coasting down a hill.
