    May 2010
    tn
    24
    Default welding blade pivot ball on dozer
    i am replacing pivot ball on dozer blade. Is there any rod to use that would be better than another? planning on running 1/8 7018. i have a trailblazer 302 and 12vs suitcase i could use but have more clean up and set up time . i thought mabye stick would be faster. any tips or ideas
    1,884
    7018 would be fine. Nothing special about them.
    May 2010
    tn
    24
    Default up or down
    7018 better running up hill or down hill?
    Nov 2011
    Edmonton
    43
    Usually better running uphill, downhill is possible but can be tougher because of slag if you don't move fast enough.
    1,884
    Maybe if you have to ask?
    7018 uphill. Don't know the dozer size but if using 1/8 rod probably 3 passes all around.
    Run NR232... It's strong and won't crack from impact.. The last ones I did I used L-56 Lincoln wire with 75/25 mix and they have held with out any problems
