    Default Please help!!!! Pictures
    ok, here we go. both sides inside need to be covered in 3/16 aluminum. im not sure if i should try and fill the holes with material and try to blend it in, or put a whole piece in front of each side. also, the transom has been cut and needs to be hinged. i dont know what route to go. i need to know what kind of hinges i need if i cant use one in picture having the door swing out. i need to know whats the easiest way to tackle this job would be and still look nice. i need some advice on this here guys. thanks for any help in advance, Joe
    Aug 2010
    1,179
    What is your process?
    I do both mig and tig. But either way I would fit in and blend down the welds. I would bevel if using tig, and gap with a steel gas trap behind if done with mig.
    If you think you are good enough to leave your welds show, covering from both sides would save you a lot of grinding a blending. But again that is not the way I would go.
    Miller Dynasty700DX
    3 ea. Miller Dynasty350DX
    Miller Dynasty200DX
    ThermalArc 400 GTSW
    MillerMatic350P
    MillerMatic200 with spoolgun
    MKCobraMig260
    Lincoln SP-170T
    Linde UCC305 (sold 2011)
    Hypertherm 1250
    Hypertherm 800
    PlasmaCam CNC cutter
    Fadal Toolroom CNC Mill
    SiberHegner CNC Mill
    2 ea. Bridgeport
    LeBlond 15" Lathe
    Haberle 18" Cold Saw
    Doringer 14" Cold Saw
    I only have a dynasty 200 so ill tig it. So you say just fill in holes don't run sheet across? And any advice on the door. 188 views 1 response?
    1,919
    Quote Originally Posted by westpoint View Post
    I viewed but I'm not understanding what you need to fill in? The triangle shaped holes on each side of the door? If so I would most likely overlap on the outside. Make the pc. nicely shaped with rounded corners & probably just stitch weld it unless there is some reason it needs to be full welded?
    Going on my interpretation of your pictures and data, not familiar with this stern configuration but here goes:
    1. Weld brackets to that plate on the seat riser shown in your "hand holding the hinge" picture. Looks like 3/16" Al, the upper end for a 200 amp Dynasty.
    2. Bolt a hinge (sorry don't have specific) that allows a 180 degree swing outward, include a latch on the exterior transom to retain the door when it's open.
    3. Rivet, not weld, a skin on the open seat bulkhead and seal it well from both sides.
    4. Bevel the plated edges and max out your Dynasty to weld up a 1/4" 6061-T6 tread plate, removable box cover for the bottom hatch, marine-grade latch hardware to secure it. Test that hatch before putting it into service since it will bear the weight of humans and their cargo.
    Just my hacker-grade .02.
    Dynasty 350
    Bobcat 250
    Maxstar 150S
    Titanium 9400
    Purox O/A
    Cutmaster 42
    alabama
    752
    Perhaps if you were a little more clear of what you wish to have done, it might bring in more responses.
    I am unsure of what you are wanting to do so I cannot help.
    2- XMT's 350 cc/cv
    1- BOBCAT 250
    1- TRAILBLAZER 302
    1- MILLER DVI
    1- PASSPORT PLUS
    1- DYNASTY 200 DX
    1- MAXSTAR 150 STL
    1- HF-251 BOX
    1- S-74d
    1- S-75DXA
    2- 12-RC SUITCASES
    1- 8-VS SUITCASE
    2- 30 A SPOOLGUNS
