Results 1 to 6 of 6
    Mar 2013
    26
    Default Tig Wearfacing / Hardfacing Reference
    My google skills are comming up short.
    Can anyone refer me to a selection of Tig Rod for wear facing, and procedures?
    Thanks.
    I have experience Wearfacing with Stick, and always air cooled but not with TIG.
    Sep 2012
    seaford de
    406
    What are you hardsurfacing?
    Mar 2013
    26
    The application is a grit valve in a Abrasive blasting system. Needs Abrasion Resistance. Not Impact Resistance.
    Material is basically 1.25" Dia round stock with a chamfer on one end.
    Plan A: is to weld it up and remachine the chamfer.
    Sep 2012
    seaford de
    406
    UTP A CELSIT 706 V. This is a tig or oxy acy wire made for pressure, impact, abrasion, corrosion, erosion, cavitation and high heat. Such as tight surfaces of fittings, valve seats, and cones for combustion engines, gliding surfaces metal to metal, milling and drilling tools. Got that from utp manual. U can also try just a simple silicon bronze. It makes a super hard surface but is not easily drillable/machinable.
    Mar 2013
    26
    Thanks for the reply.
    My local supply suggests "Weld Mold 959"
    http://www.weldmold.com/index.php?op...steel&Itemid=1
    Sep 2012
    seaford de
    406
    That should work.. its used on shear blades and dies usually
