Results 11 to 20 of 26
    Los Angeles
    2,840
    Quote Originally Posted by GT6Steve View Post
    This is not intended as intruding on the thread, but rather germaine.
    I have a 165 and have been struggling to learn it for a couple years now. Just myself and the Gurus on this forum. I bought a foot pedal as I couldn't work the thumbwheel and I just converted to the WP-17 torch and silken hose assembly.
    Both are major improvements IMHO. From a welding nobody BTW....
    That said. Trying it out today was a PITA as nothing seemed to work the same. I'm ignorant.
    Instead of trying to join pieces should I just work on a single clean piece and get to run smooth beads for a while? I suspect that's the learning path, what say you all?
    Thanx, Steve
    Yes. Grab a flat piece and only use the torch NO filler. Start the puddle and work across the plate working on consistency with the bead profile.
    Once you have that down you can introduce the filler- still working on flat plate/sheet
    1/8" is plenty or what ever you have around but you don't want it too thin or you'll just blow through.
    Once you get the that down you can start on butt joints, lap and then fillets.
    Ed Conley
    MM252
    MM211
    Passport Plus w/Spool Gun
    TA185
    Miller 125c Plasma 120v
    O/A set
    SO 2020 Bender
    You can call me Bacchus
    Jan 2007
    Montana, USA
    233
    Thanx, Steve
    Steve,
    If you can post some photos, we can more easily iron out your technique.
    May 2013
    2
    Default multimatic 200 tigger
    Hello fellow tiggers I trying to figure out if you can tig weld aluminum with the miller multimatic 200 tig due to the fact that its a lift arc tig. Will get your tung dirty on start up? Can you run the tig on this machine as a non-lift arc tig process if so is it as simple as getting the foot pedal and wam bam thats it
  4. #14
    Jul 2011
    Huntington, NY
    118
    You need AC output to weld Aluminum in the real world. The Multimatic lacks that.
    You can weld thick aluminum with ultra expensive lab grade Helium on DCEN, but not too convenient.
  5. #15
    Jun 2012
    13
    Default I've narrowed it down or not!
    I'm at a cross roads for the diversion 165 and 180. I was leaning towards the 165 but the 180 comes with the foot pedal. Also is there a huge difference between the two I mean they are both 3/16 steel or aluminum machines. Besides the 120 and 240 volt, digital display and foot pedal for the 180. What do you think, is it worth the extra money for a beginner? Decisions, what would you do in my shoes? Thanks again Steve
  6. #16
    Aug 2010
    Los Angeles
    1,165
    Quote Originally Posted by nywelder View Post
    If you have the means, get the 180. Having a dual voltage tig, I cart it everywhere. The resale value holds better than the 165 IMO. Like you said, it comes with the pedal, which I guaranty you will purchase.
    The big picture though is that you will learn in rapid fashion. These Diversions are so simple.
    Good Luck with your decision.
    Miller Dynasty700DX
    3 ea. Miller Dynasty350DX
    Miller Dynasty200DX
    ThermalArc 400 GTSW
    MillerMatic350P
    MillerMatic200 with spoolgun
    MKCobraMig260
    Lincoln SP-170T
    Linde UCC305 (sold 2011)
    Hypertherm 1250
    Hypertherm 800
    PlasmaCam CNC cutter
    Fadal Toolroom CNC Mill
    SiberHegner CNC Mill
    2 ea. Bridgeport
    LeBlond 15" Lathe
    Haberle 18" Cold Saw
    Doringer 14" Cold Saw
  7. #17
    Sep 2008
    Dalton, GA
    120
    I would definately recommend spending the extra $400 or so for the Diversion 180 if that is doable for you. The footpedal is worth most of that and the dual voltage lets you practice almost anywhere.
    I would also suggest you consider the Thermal Arc line. They have great reviews. I have used 2 of them briefly and was impressed.
    Burt
    _______________________
    Miller 211AS
    Miller 375
    Miller Syncrowave 250
    Miller Thunderbolt XL
    http://www.10FtDrillBit.com
  8. #18
    Jun 2012
    13
    I made some calls today and the diversion 180 is going to be on rebate until August but the 165 is only till the end of the month which will give me time to save and go the extra for the 180. I have looked into the thermal arc and the lws do not carry there consumables but miller is readily available plus I prefer USA made. So I guess I will wait a little longer. I will keep practicing brazing to hone my skills until I can tig. Thanks for the info Steve
  9. #19
    I think you need to find a different LWS. The TA186 comes with a series 26 air cooled torch. Both Diversions come with a series 17 air cooled torch. Both 17 and 26 series torches use the exact same consumables. If you buy a Thermal Arc just tell the counter guy you have a Diversion and the collets, collet bodies, gas lense, or gas cups they sell you will all fit.
    Diversions sell fast when they hit craigs list. A lot of people get one to learn TIG and either decide they don't like TIG or want a unit with more buttons and the Diversion gets flipped.
    It's a tough choice, if you are certain you are going to get into TIG I'de go with the Thermal Arc right from the start.
  10. #20
    Oct 2012
    4
    Default Want to learn tig, decisions?
    I would suggest a hard look at the thermal arc. Although it is manufactured over seas, I believe the diversions are only assembled in the US and sourced over seas as well. On the thermal arc, there are quite a few more options and included accessories not to mention the stick capacity.
