Page 1 of 3 123 LastLast
Results 1 to 10 of 26
    Default collars for dumbell
    Hi, I wonder how they made the collars for this load able dumbell Handel.
    I made one before with 50mm/2 inch washers but they were a bit thin
    The bar and Handel is 2iinch/50mm
    Dec 2011
    388
    There is too much paint on it to tell. Could be a casting, a forging, a welded assembly or machined from a large enough bar.--Meltedmetal
    Jul 2009
    Australia
    1,031
    Could be lathed. the ones with thread on the ends are.
    Ji
    Grip it and Rip it
    Here's better pics
    Apr 2011
    360
    Default Wow...
    Never have I seen something so simple be treated like it needs to be sent to NASA for analysis...!
    It is punched out of flat stock...like plate or bar.
    You can see the die marks on the edge...or punch marks, however you decide which one leaves them.
    Just For Home Projects.
    They cut from plate not punch if they are old it was oxyfuel. Newer ones are made using plasma or laser.
    1,837
    The discs are burned from plate. Either oxy/acet or plasma. My guess the ones in the pic are oxy/acet. With a burning machine doing a large qty. the cost would be cheap. To make just a few it wouldn't be profitable for resale.
    Today plasma would most likely be used.
    So they just plasma cut the holes out of a 1/2 inch 25mm plate?
