Results 1 to 8 of 8
    Default TIG shielding gas alternatives
    I am TIG welding stainless and am using 100% Argon. I will run out of my argon over the weekend.
    I have two cylinders of an argon + helium blend that I use on stainless using MIG.
    Will this blended gas work with TIG welding stainless? The term "heli-arc" is synonymous with TIG welding but I am un-sure if this will work.
    Thanks guys!
    Tom
    Ukiah, Ca
    280
    It should work just fine. The arc will be hotter with the helium blend, so lower your settings.
    AutoArc 230 (MM 210)
    3035 spoolgun
    Spectrum 625
    Dialarc HF w/Coolmate 4
    Thank you Bob!
    That's what I was wanting to hear
    Apr 2010
    304
    Is that gas a tri-mix with CO2?
    Argon and helium only.
    Jun 2009
    Las Vegas Nevada
    132
    Bob, can you explain to a novice why the arc will be hotter with Helium? Less dense gas allows a stronger arc??
    Miller Diversion 165
    1966 Bridgeport Mill
    Leblond 15x 35 Regal Servoshift lathe
    Solberga SE 1425 Drill Press
    Bigass Bandsaw
    Hydraulic press
    small surface grinder
    Belt sander
    Tons of grinders and hand tools
    Knife edge Balancing rollers
    Heat and AC in the garage
    Jags and racing Triumphs
    Dec 2011
    430
    From "The Miller Tig Handbook" available in pdf format on this site.- Meltedmetal
    Unlike argon, helium has high thermal conductivity. Due to
    this higher thermal conductivity, the arc column expands,
    reducing current density in the arc. The arc column will
    become wider and more flared out than the arc column with
    argon shielding gas. Figure 4.13 illustrates the two arc
    columns. The more flared out the arc column, the more work
    surface area is being heated. The heat at the center of the arc
    can move more readily downward toward the colder metal
    at the bottom of the workpiece. This results in a deeper
    penetrating arc. Figure 4.13 also illustrates the resultant weld
    beads and the difference in penetration produced by argon
    and helium.
    Default update
    Well I tried the argon & helium mix. I works but is much hotter.
    I slipped up and didn't realize I was on my last bottle.
    I am definitely used to 100% argon.
    Thanks,
    Tom
