Page 1 of 3 123 LastLast
Results 1 to 10 of 22
    1,890
    Default Komatsu boom crack repair
    Started this on Thursday afternoon & finished up on Friday. Cracked twice & welded by the companies mechanic (he's good but always rushed). This time he wanted me to do it. Right where the side plate meets the casting. Gouged it out completely so I had a 3/8" open gap to the inside. Snaked a piece of 1/4" bar inside with a rod tacked to it to hold onto. Pulled it tight up against the inside & tacked it good. Preheated, then welded it up.
    Not really much to see. Basically like a weld test.
    Apr 2008
    254
    I never realized there was a casting on the end. Thought it was all built from formed steel. The casting then is steel?
    Is this a usual location for failure ie is this an engineering design issue or working outside of engineering specs?
    I assumed you used wire as in other projects? How did you figure the preheat..was it just to warm it up or were you trying for a certain range? Did you attempt to maintain a certain temp interpass?
    Thanx again for taking the time to post pics, real interesting!
    1,890
    Yes it is cast steel. Not sure if it's common but the rep said he has seen this before on this model (PC400). The machine also has 11,000 hours on it.
    The first passes I used 7018. One from the backer strip to the side plate & one from the backer to the casting. I did this because stick usually burns out any contaminants better than wire & I wanted to make sure I had a good root in there. I then finished with innershield wire doing stringers. I had about a 3/8" gap at the root & maybe a little more than 1" gap at the outside.
    I didn't have my temp gun with me but tried to get it to about 300* at the start. There is so much steel there that I didn't worry to much about interpass temps. I just didn't rush it & cleaned each pass real good.
    Jan 2013
    Ohio
    57
    MMW...I'm still learning....what do you mean by stringing?...like the pics an explanation on how you did the repair
    Sep 2012
    seaford de
    406
    i have fixed about 5 of these so far on pc400's.. and also where the main boom cylinder goes into the bushing. The last one i fixed was from a bad weld, it was full of porosity on the whole bottom half of the weld. Not real good QC to let something like that come off of the line
    3,936
    Quote Originally Posted by weldonwelding View Post
    Prob robotic welded and the 18 yo QC guy didn't care or didn't know. I saw it alot...Bob
    Apr 2006
    TAXACHUSSETTS
    1,491
    Of course you have.You,ve seen it all.
    BB402D
    TB300D
    DIMENSION652
    MM250X
    MAXSTAR140
    HT/PWR-MAX1250 PLASMA
    Lodi, CA
    1,302
    Quote Originally Posted by admweld View Post
    lol ......
    Thanks, Billy, you just made my day.
    Apr 2006
    TAXACHUSSETTS
    1,491
    lol ......
    Not just once either Joe.Five times.
    BB402D
    TB300D
    DIMENSION652
    MM250X
    MAXSTAR140
    Apr 2008
    254
    I was thinking about the backer and theres no danger of it becoming a problem later on? My familiarity w/ backers is they must come off. I think they can become stress risers. Also did you try to match the backer to the original material or just use mild steel/whatever you had on the truck?
    To me it seems very difficult to repair heavy equipment. There are so many variables you may or may not know or be allowed to know. Ag equipment seems a lot more doable. Guess its all about what you know....
    I find these threads very interesting! Thanks a million for explaining what you did and why.
