Results 11 to 15 of 15
    Mar 2012
    Southwestern Ontario
    44
    Default air carbon arc gouging?
    That would be great if you could thanks
    1,315
    Quote Originally Posted by rustymfg@hotmail.com View Post
    .070 is about as close as I can tell.. Get you real close anyway. The lower (Aluminum on the K-2000) pad unscrews on this unit. It has the holes in it. Might see if they would interchange with the K-4000 pad. Might be a simple/cool fix.. It's good for 450 amps..
    Sep 2009
    Canada
    198
    Quote Originally Posted by gnforge View Post
    Mostly use my Hypertherm 85 with gouge tip, you turn it up or down as needed. I bought another hose so i can just plug & go when need.
    Still keep carbon arc for hard to get into areas but hardly ever use it anymore
    I use my plasma frequently for gouging as well.
    Problem is, the arc air set up costs 1/10th of what your plasma costs to buy.
    Miller Bluestar 2E
    Thermal Dynamics Cutmaster 52
    Torchmate CNC table
    Ironworker Welder
    Operating engineer
    Dec 2012
    Simcoe Ontario
    106
    If your gouging a lot don't use your own machine. Rent one. It's a good way to burn your machine out. The rentals are recalibrated often cuz everyone uses them for gouging.
    1,919
    Why not just buy a K2000 instead of messing with a K4000? Do you already own a K4000? The K2000 is plenty beefy enough for 3/16"/1/4" carbons. The K4000 is larger in physical size also. It would be overkill for running 3/16" carbons.
    See my post #3. You need a K2000 & it work well with your wheelbarrow compressor.
