Page 1 of 3 123 LastLast
Results 1 to 10 of 21
    Mar 2009
    ny
    72
    Default miller mig power cord extension
    the guy i bought my mig welder from gave me an extension cord he made up. it is super heavy duty and about 50 ft long....problem is, it is still as can be... I have seen quality power cords that are totally limp. i imagine its the stranding on the copper wiring....
    I searched for power cord extension online...but it isnt obvious if the feature of limpness that i am looking for is in the cord....
    what is the type of cord i am looking for and how is it described...even better does anyone know where to buy one? single phase 240 volt 50 amps( millermatic 250.
    I can use the one I have, but id rather get a more controlable cord
    bob
    Nov 2012
    Northern Arizona
    539
    I have one built out of 8/3 soow cord. Fairly flexible. I wonder if yours is made from romex ? That is not suitable for the application of extension cord!
    MillerMatic 251
    Maxstar 150 STH
    Cutmaster 42
    Victor Journeyman OA
    Sep 2012
    seaford de
    406
    Most people make their own up. If you want a 50ft cord then 8/3 so cord will be fine.. you will have trouble finding one already made up.. and if you do then it will be really expensive. Try your local electrical supplier
    Wa
    628
    Just get raw wire from your local hardware store and put what ends match your receptacle and plug on welder. Sounds like maybe someone made your current cord out of solid wire and not stranded. Like Elvis said, this is not a good idea.
    Jul 2010
    Four Flags city
    304
    I use 6/3 SO or SJ cable(stuff that extension cords are made of),add the ends you want from Menards,Lowes or Home Depot.
    I have never seen a cord like this for sale commercially.
    2,927
    Slight correction- he needs CORD not wire.
    Wire goes in the wall to feed a receptacle.
    Cord is what you want for a power cord or an extension cord.
    The price of cord is not cheap and the connectors are not exactly cheap either.
    $123.00 for a pre-made Cord 50' cord
    http://www.brweldingsupplies.com/wel...y-duty-8-3-50/
    Build yer own:
    $39.00 bux for connector set
    8/3 cord runs around $1.75-2.00/ft
    50'x 1.75 = $87.50 + $39.00 = $126.00
    4,442
    this is a great place to buy a ready made cord, the cost difference is moot. It calls for an 8,,,, this is at rated output,,, I use a 10 on occasion becaue I am small short circuit only but if you intend to wring the guts out of it in spray 8 is the right wire, works great for buzzers. Only reason not to use it is weight or because you already own something else and the demand is light.
    4,442
    its acyually a pretty rare day i have to use a cord for a welder, i will move or add outlet if there is much chance it will be a regular event. I had outlet 20 ft from hoist and i got a cord but it was well worth it adding another recept, same wire, not used same time and same breaker ratings.
    Even though a compact can run on 50 I put 30 in at their "home" outlets, figure it cant hurt to close the gap a bit for free.
    Wa
    628
    Broccoli is correct its called cord. My fault.
    Sep 2012
    seaford de
    406
    Quote Originally Posted by Broccoli1:307162
    Build yer own:
    What is a connector set? You just need a receptacle and a plug. They wire goes into them and under screws. This post is going complicated... for such a simple thing as a cord. Lowes carrys cord up to 10/3 at least the one by me does. And no one there will guide him like they should. That's why I said he needs to go to a electrical supplier.. they will set him up.
