    Jun 2004
    WY
    11
    Question Bobcat won't start
    I have a Miller Bobcat 225NT with an Onan engine that won't start. One day everything was fine the next day I went to start it and nothing. The battery is good and charged. I Have checked a fuse that is near the starter and its good. But it doesn't crank....nothing. Any ideas on how I can trace the problem. Can I bypass the switch and see if its that? Any recommendations?
    8,018
    Corroded engine harness plug, mounted on the baffle , just follow the harness from the starter back towards the front.
    Jun 2004
    WY
    11
    Is it usually something can be cleaned or typically replaced?
    8,018
    Sometimes a mere cleaning will fix it, most of the time however, you'll have to jumper wires around it.
    Jun 2004
    WY
    11
    Thanks I'll let you know how it goes.
    Jun 2004
    WY
    11
    Just had to clean it up and its starting and running fine. Thanks for the help!
