Results 1 to 3 of 3
Thread: XMT-350 issue
    May 2013
    1
    Default XMT-350 issue
    We recently purchased 6 XMT-350's and we cannot weld the parameters that we used to weld with the other XMT-350 that we own. We are in a tig process, using the profax tig torcha and the CK worldwide thumb slide controller. Is this combination still compatable with the new XMT 350"s or not. Has Miller changed anything that will not allw this to work.
    Oct 2007
    Cave Creek Az
    1,097
    Maybe you could state what parameters you are trying to weld to, as well as the type of metal, gas, and where the machine dials are set.
    Oct 2004
    Edmonton, Alberta
    8,351
    Nope nothin has changed, probably a problem with the machine, or your remote controller's switch isn't working. As the once the 350 senses its got a remote, nothing much is happening without some sort of switch to turn it on.
Tags for this Thread
