Results 1 to 2 of 2
    May 2013
    Default Regency 250 wiring trouble
    Hello, I have an old regency 250 that has worked well for quite some time. Recently it was giving me problems by not providing gas flow. I talked to a few guys and they said it was probably my relay, so I went ahead and bought a new one. Before I got the chance to install it someone unhooked all the wires to that relay and did not mark which pins they were supposed to go to. Now I have no clue where any of the wires go on the relay. about the relay it says CR 1 so I am assuming it is the control relay? The wires are numbered 38, 37, 36, 34, and 30. I am not very experienced working on welders so any help would be greatly appreciated. Thank you
    Dec 2011
    416
    Wiring diagram is available in the owners manual. Owners manual is available in the resources section.----Meltedmetal
