Results 1 to 10 of 15
    Apr 2013
    4
    Default Aluminum I beams
    Can any one tell me what size 6061-T6 beams I need for a walkway spanning 24 feet by 36" wide? Thx
    1,928
    Any other supports/truss or will the I beams be the only thing supporting all the weight? Will they be flat or crowned?
    4,507
    look at an aluminum scaffold pik
    Apr 2013
    4
    Default I beams
    Supported each end by existing walls. Flat thx
    Apr 2013
    4
    Quote Originally Posted by Pjenks835 View Post
    PS low traffic area office environment
    Nov 2009
    western mass
    213
    I'm no engineer but I would think they'd have to be fairly big. 24' no supports. I would think there would be a lot of deflection. If it needs railings you could incorporate a truss system into that. But really a lot of variables. Need a lot more info
    4,507
    this is really something where the whole picture is needed, design etc.
    Apr 2013
    4
    Thx guys. My gut tells me it needs a center support. I'll bite the $ bullet and have an engineer spec it.
    Sep 2009
    Colorado
    238
    Default Deflection is key
    The thing about long beams, and especially aluminum, is the strength is only part of the story. Deflection (sag) is likely the limitation. Even if is is strong enough to be safe, no one will want to walk on it if it sags two inches in the middle.
    A typical deflection limit for a live load would be L/360, about 0.8 inches in a 24 foot span. Some architects use lower limits to make the floor feel more substantial. As I understand it, that would be the difference from the no load deflection and the fully loaded case. You would have to figure out the maximum load for the beam, and then calculate the deflection.
    Good idea to get an engineer involved. Should save money in the end by preventing overdesign or rework.
    Richard
    Aug 2004
    Milan Michigan
    1,893
    My guess is a 12" beam that weighs about x 14.29Lb Ft.
    This is for 2 beams running parallel with a plank of some type connecting them together on the top side and 2 crossmembers maybe 3 on the bottom.
    However, It does not make sense that you would not have a handrail, If the hand rail is done right you could use a much smaller beam.
    I'm not a engineer but Its close enouph for quoting the job.
    And this is for foot traffic.
