Results 1 to 10 of 16
    Apr 2013
    5
    Default First time welding, miller 211
    Hi guys.
    I was in need of a small home shop welder. After reading the reviews I settled on a Miller 211 setup.
    These are my very first welds on scrap 1/2 plate using both push and pull while making little circles on 110v.
    My question is this. It appears that the weld is a little tall (excessive reinforcement). Is this because I was just laying down beads on a plate without a groove? Are my machine settings wrong? Am I doing something wrong? will 220v help? Or does this look normal for just laying down beads?
    Wa
    632
    Looks a little cold but that's kinda what you get not welding a joint where you are filling a void of some sort. Try to do a v beveled butt joint on 1/8 if using 110. Are you using auto set?
    Nov 2012
    21
    Because your welding with a 110v welding machine on 1/2" steel. Too cold, wrong wire. Good looking weld though...
    Dec 2012
    Sweetwater, TX
    201
    You've got the straight part going well for you.
    I would recommend practicing on something thinner (1/8") so you can really see the weld bead bond with the material. About 1/8" is going to be the limitation of the 211 using 120V. According to the miller mig calculator 1/8" will require 140-150A for short circuit transfer.
    http://www.millerwelds.com/resources...calculator.php
    The 211 is only rated at 3/8" single pass (using 220V), so doesn't surprise me that the beads look tall like they are cold for that thickness of material.
    That is an example of one of the precautions about mig how it is easy to lay down a bead that looks pretty even though it is way too cold for the thickness of metal being welded. You might think about making some practice T-joints and bending them over with a hammer to see how your welds hold up.
    Sep 2012
    seaford de
    407
    That looks pretty good for your first time. Im actually surprised how straight they are.... most first welds and quite a few after dont look that uniformed. Get some 3/16 steel plates and practice on that.
    Apr 2013
    5
    Thanks for the advise.
    To answer some questions, yes I was using the autoset feature. I tried manual settings and couldn't really tell much of a difference. I'm also using .030 wire and 75/25 gas.
    So I made a 55ft extension cord to run from the dryer outlet to the garage. Kind of hokey, but it works. It definitely made a huge difference with the heat! I'm much happier with these beads. There is a little more spatter, but considering that the plate has some light surface rust and I didn't prep it at all, I don't think that these are bad looking.
    Wa
    632
    Looks a bit better. On the lower pic, the bottom bead you are moving too fast, on they same pic the bead above the bottom one on the left looks pretty good. Try a joint, looks like you got the basics down. Keep having fun!!
    Dec 2012
    Sweetwater, TX
    201
    I was going to say the same thing about the travel speed too fast on the bottom bead, you beat me to it Cgotto6.
    When you do get some thinner plate you might try stacking beads like your doing on flat plate to help you with watching the bead tie in with your last bead and the plate. Practicing that over and over will help get your travel speed and movement uniform.
    I'd say your off to a great start. I had never used the autoset on my MM140 before I sold it since I only ran it on Flux wire (didn't have a bottle at the time).
    All I ever used was the chart settings and they really were a great starting point. Don't be afraid of using the chart setting to and fine tuning your wire speed and voltage a little here or there to really get a feel for how everything affects the beads.
    A lot of people just set the machine and then jump to projects right away without learning how things affect the bead. Its great to see you are working on your beads first.
    Keep up the good work.
    2,932
    That should slow him down fo' sho'
    Wa
    632
    Hey it's legal here in Washington, haha.
