    Apr 2013
    Default buying a used welder info
    Hi,I am going to look at a Miller Syncrowave 351 later today and wanted to know if there was anything I should look for. Its a 1997 with a tig runner package and a coolmate 4 along with a few other items.I have never tig anything but stick and mig I have done for some time. Any suggestions is much appreciated.. Ty
    Wa
    632
    Make sure you try it out on dc, ac, stick, etc. different amp ranges. If you don't know how, bring a friend who does. Good luck, hope its nice for a good deal! Let us know how it goes. You can also look up the serial on millers website to get more info about it. I'm not sure if that model has the counter for run hours and arc starts, gives an indication of its use history. You could look up its manual on millers site to find out how to do this.
    2,932
    You have the power to run that thing?
    Jan 2013
    5
    Default spoolmatic 30
    Im lokin at a spollmatic 30 used for $500 its just missing the top cover off the gun would that even matter? what would a new one cost?
    Sep 2009
    Colorado
    225
    Default 100 amps at 230 volt
    Without looking up the manual, I would think that you would need around 100 amps at 230 volts to come close to getting full power out of it. The manual would give you the real number. Broccoli has the right question.
    Richard
    Wa
    632
    Quote Originally Posted by wideglide View Post
    Start your own thread.
