Page 2 of 2 FirstFirst 12
Results 11 to 18 of 18
    Apr 2013
    Hertford NC
    22
    Quote Originally Posted by cope View Post
    I se no need to go larger than 200 amp.
    Good deal.
    Appreciate the advice!
    Sep 2012
    seaford de
    406
    Consider this.. look at the clamp that came with the 200amp machine.. the piece of crap, then look at the tweco 150 amp clamp... big difference, you would probly be fine with the 150 but just to be safe id go with the 200amp.
    Apr 2013
    Hertford NC
    22
    Quote Originally Posted by weldonwelding View Post
    Cool, as I just ordered mines. Thanks for the help everyone!
  4. #14
    Nov 2007
    142
    Maybe a stupid question here but, how can you tell the difference between a good and great ground clamp? If you have an arc wouldn't that constitute a good ground (clamp). I guess being type A (as my wife says) give me some concrete evidence...resistance ohms maybe
    MM 211 W/ Spoolgun
    Diversion 180
    Spectrum 375 X-TREME
    Portable Victor O/A
    Palmgren Bench Drill Press
    14" Evolution Dry Saw
    IR 60 Gal. 3 HP Compressor
    Speedglas 9100x
    My Brain
  5. #15
    Houston, TX
    900
    Quote Originally Posted by benny365 View Post
    You will have an arc if you have continuity, yes, but the cheap clamp doesn't have the spring pressure for a good contact, and will wind up with arcing and pitting on the contact surface. The heavier duty clamps like the Tweco are better conductors and have stronger springs. The initial cost isn't that much, but the life of the Tweco is much longer than the cheap ones. All you need to do is look at them side by side.
  6. #16
    Jul 2010
    375
    That's the same clamp that came with my 2010 Syncrowave 250DX Complete.
    The spring in mine broke after 2 years.
  7. #17
    Jul 2010
    Four Flags city
    304
    I actually like the 500 amp sheet metal clamps.......but there are no fork lifts near or minimum wage grunts using my stuff so they last.Yup,they are over kill but it's not like it matters.
    To me all brass ground clamps are not the same.These things drive me batty,
    http://victortechnologies.com/tweco/...rodID=92051120
    They never seem to stay clamped.
    Now THIS I can get on board with,
    http://victortechnologies.com/tweco/...rodID=92051320
  8. #18
    Apr 2013
    Hertford NC
    22
    Quote Originally Posted by big mike View Post
    Funny I was thinking about getting the flat type but changed my mind at the last minute.
