Results 1 to 2 of 2
    Apr 2013
    3
    Default Millermatic 350/350P and Weld Procedure Specification
    Using a Millermatic 350/P... I've got to follow the parameters of an approved weld procedure specification pretty close, namely Amps, Volts and Wire Feed Speed.
    I can see how to adjust Volts and Wire Feed Speed, however how can I adjust the amperage, and how do I see the machine is actually operating within the amperage range I need to stay within according to the WPS?
    Other welding machines I've used in the past had dials and gauges for both Amps and Volts.
    Thanks!
    2,967
    6-4. Weld Status
    When trigger is released on a MIG gun, spool gun, or push-pull gun, the last actual amperage and voltage will be shown on the displays for 5 seconds. The VOLTS and AMPS indicator lights will illuminate under the displays and each value will appear in the corresponding display.
    If a programmed value requires adjustment after the arc is extinguished and during the 5 seconds display of actual values, turning either knob will cause actual values in the displays to be replaced by programmed values for adjustment purposes.
    http://www.millerwelds.com/om/o1327ah_mil.pdf
