Results 1 to 10 of 12
    May 2007
    140
    Default Splicing anchor chain
    I just purchased another 100' of 3/8" anchor chain for my boat which i want to splice in with the chain i currently have. I know they make chain coupler which are basically two halfs which you put together and hammer these tabs (kind of like a rivet) to hold the two halves together. But what about cutting open one link of the chain and tig welding it back shut? Is there any reason why this can't be done? Seems stronger and cleaner then using one of these couplers. How would you guys splice chain? Thanks in advance.
    Sep 2012
    seaford de
    407
    Since you said boat, not ship... im gona assume that its not gona hold the weight that it is made to hold. I would just weld it with 70s6 filler, bevel it well so you get full pen.
    Oct 2005
    North Central Indiana
    783
    How about using a SS rapid link and hit the threads with some red loctight.
    http://www.1st-chainsupply.com/image...apidlinkSS.pdf
    Illinois
    653
    Hi, here's a couple of u tube videos that will help.
    http://www.youtube.com/watch?v=k_LA_R4ifYk
    Nothing to it !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
    First post here. Figured I'd reply on something I have some experience.
    I work for a distributor of all sorts of marine products. Primarily, anchors and chain. While I work in the machine shop, we have a few fabricators that have to join chain on a fairly regular basis.
    Basically, you cut the link on one side allowing you to insert the end of the second chain. We use a few techniques, but basically, heavily bevel one side and weld. The opposite side is then beveled and welded. We are after a 100% weld. This is true of all chains we join to preserve the rated strength of the chain. A word of caution. Some smaller chain that may be used through a windlass will require the weld to be aligned on one side of the chain. Some windlass heads can't handle the width change.
    Also, the proper way to join anchor chain without welding is with the use of a chain connection link or a kenter link. The kenter links come in various grades and are largely an import product making them somewhat more economical than the chain connecting link.
    And regarding grades. If it is stud link chain, a stud that is not welded is considered grade 2 or mill, stud welded one side is grade 3, and stud welded both sides will be grade 4 or oil rig.
    And to further muddy the waters, we sometimes wrap weld chain for use in the mining industry as chain curtain for the rock crushers, grizzly bar setups.
    We have stuff from jack chain through 4"links. At hundreds of pounds per link. We even have anchors over 20k pounds for oil rigs. So I apologize if it's a bit TMI!
    Dave
    Oct 2005
    783
    Good info fishinm thanks
    Feb 2013
    Kansas City, Missouri
    11
    Thanks for the chain tutorial. I guess pictures would be getting greedy. It's never TMI if it is interesting. Thanks again
    1,920
    To answer the original question, if you're confident in your welding abilities then yes it can be done. For what you are describing it will be used for it should be fine.
    I would not recommend this for any lifting chains & if you do weld it together it should be marked somehow so that in the future it does not get used for lifting. Not saying this chain is rated for that in the first place.
    Why wouldn't you spend a couple bucks on a splice link? A lot less time involved & better corrosion resistence than something that has been welded.
    Oct 2005
    783
    I tried finding installing a kinter link up on youtube and only found out how to take one apart. See pictures of them on google.
    Here's a link that will give you some basic specs.
    http://wachain.com/chain-attachments...achable-links/
    Dave
