Results 1 to 10 of 19
    Oct 2005
    North Central Indiana
    782
    Default simple chopsaw stand
    I made this so I could roll the saw outside. I centered the motor over the 4" sq tube riser so down forces would go straight to the floor to help with balance when cutting. The angle irons end over the center of the axle. The handle slides in out of the way. For those that don't know, you can click on the double lines down at the bottom left by the pictures and stop the slide show and see the pictures one at a time by clicking on the arrows on the screen.
    http://s1298.photobucket.com/user/cy...deshow/Chopsaw
    Sep 2012
    seaford de
    406
    I have never seen any of your pics. When i click on the link u paste it sends me to a sign in page. Am i the only one?
    Sep 2012
    seaford de
    406
    Also... it may be cause im on here with a stupid.. i mean smart phone
    Apr 2009
    Upstate SC
    139
    Pics work fine for me. Nice stand.
    CG
    Old Miller Swinger 180 Buzzbox
    Miller Diversion 165
    Smithy Lathe/Mill
    Oct 2005
    782
    Quote Originally Posted by chewinggum View Post
    CG
    Thanks chewinggum, it's fast and easy to build and doesn't take a lot of material and shoots the dust and dirt to the ground. no clean up
    Oct 2005
    782
    Weldon, I have it set to public, it should be showing up on your dumb phone.
    Oct 2005
    782
    Quote Originally Posted by tackit View Post
    How's the new Bobcat doing?
    Sep 2012
    seaford de
    406
    Quote Originally Posted by tackit:306908
    I am using my tablet now and its the same thing. A sign in/sign up for photo bucket page, no matter what I click I have to sign up for it
    Sep 2012
    seaford de
    406
    Quote Originally Posted by tackit:306909
    Its doing great. At 98hrs now so time for a oil change. It took a while to get used to it. Its a lot different than my other welders, completely different arc, its not better and its not worse... Just different. And also took a while to find that sweet spot, I change rods and sizes so frequently that I would forget where I was on the previous rod.
    Sep 2012
    seaford de
    406
    This is with the new bobcat and a hf-251d. No pedal, no on/off switch.. just a hot torch and a gas valve.
