Results 1 to 10 of 10
    Mar 2009
    ny
    72
    Default just bought a MIG welder....question on gas
    I finally bit the bullet and bought a welder for my home, for doing projects on my boats. I bought a Miller 250 with a 30A spool gun. i also got a 50 ft extension cord...the cart has a place for 2 bottles of gas. the guy said one is for pure argon and the other is for argon -co2 mix( for welding steel). OK ill have to rent the bottles. DO i really need the mixed gas bottle? the reason i ask, is that i have a TIG machine at work and we use ultra pure Argon on that machine.. and i weld aluminum, stainless steel and regular steel with the same gas....seems to be fine.
    gan i use the pure argon at home with my MIG machine to weld steel ( knowing I have to revert the regular wire feed in the machine)
    thanks
    PS the mig welded way way easier than i had heard...we did test welds before i bought it, and we used just aluminum sitting on the shelf..didnt wire brush it or nothing...welded fine9 to my eyes.... I was welding in 5 minutes...of course my welds are a little high......but the finess is like learning to use a clutch in a standard car.....
    bob
    you can use pure argon for mig welding steel and stainless. The only difference is the mix is cheaper. If you are mig welding aluminum, you are going to need pure argon anyways. Keep an eye out on Craigslist for owners tanks. They should be about $80-$100 bucks. Renting them gets expensive if you aren't doing production work and they are just sitting in your garage.
    Aug 2010
    Los Angeles
    1,163
    Lift the cover on the spool side of the machine. The chart will tell you which gas to use.
    Miller Dynasty700DX
    3 ea. Miller Dynasty350DX
    Miller Dynasty200DX
    ThermalArc 400 GTSW
    MillerMatic350P
    MillerMatic200 with spoolgun
    MKCobraMig260
    Lincoln SP-170T
    Linde UCC305 (sold 2011)
    Hypertherm 1250
    Hypertherm 800
    PlasmaCam CNC cutter
    Fadal Toolroom CNC Mill
    SiberHegner CNC Mill
    2 ea. Bridgeport
    LeBlond 15" Lathe
    Haberle 18" Cold Saw
    Doringer 14" Cold Saw
    Feb 2012
    Wa
    539
    You can't mig steel with pure argon. You can run co2 or some blend of argon co2. The most commonly used is a 75/25 mix, or also referred to as c25. When migging aluminum with the spool gun you must run pure argon. Using straight co2 will result in a little more spatter than with c25. Stainless requires a tri mix it stainless mix. Obviously you can run flux core with no gas as well, but will have different characteristics. Then there is dual shield and many other blends for different configurations...
    northern NJ
    1,832
    Do not use pure argon for steel & stainless mig.
    Aluminum mig = pure argon
    steel mig = argon/co2 mix or straight co2
    Stainless mig = trimix
    MM250
    RCCS-14
    Dec 2011
    388
    There is a good explaination of the why's and the wherefore's in Praxair's Shielding Gas Selection Manual. Should be available at the Praxair website.-Meltedmetal
    Feb 2010
    YOUNGSTOWN, OHIO
    172
    I will have to second both MMW and Meltedmetal.
    You DO NOT want to use 100% argon to MIG anything steel.
    JIM
    Millermatic 350P Aluma Pro
    Maxstar 150 STL
    Trailblazer 302
    Suitecase 12RC
    Extreme 12VS
    Extreme 8VS
    Spoolmatic 30A
    Miller HF251D-1
    Passport Plus
    Spoolmate 100
    Hypertherm Powermax 45 and 85
    Dake 75 ton H-Frame Press
    JD Squared Model 32 Bender
    Miller Digital Elite
    Oct 2005
    North Central Indiana
    782
    pure argon doesn't offer the penetration 75/25 blend does on steel, bead shape and depth along with arc characteristics are effected with different gas mixtures.
    Jul 2010
    Four Flags city
    298
    There is tri mix for steel,argon,CO2 with a touch of oxygen and then there is tri mix for stainless which is helium,argon and a touch of CO2.
    Alright... goofed that one. I haven't used my mig in a while and forgot about using pure argon while mig welding steel and stainless.
