Results 1 to 3 of 3
Thread: DVI2 Help
Hybrid View
    Default DVI2 Help
    Picked up a DVI2 welder, using gasless wire and not for sure how to change polairty for gasless, picture attached of how its wired now.photo.jpg
    Nov 2012
    Northern Arizona
    571
    The short wire should stay on that stud and the long wire should be on the red stud. If you switch to gas you'll need to change them. Where it is now you won't be able to weld.
    MillerMatic 251
    Maxstar 150 STH
    Cutmaster 42
    Victor Journeyman OA
    Quote Originally Posted by elvis View Post
    Thanks much, i will change it tonight and give it a try.
