    116
    Default Gas flow question.
    If I set my gas flow at for example at 20, I have noticed that when the trigger is on, for example MIG welding, the needle drops down to 12. As soon as the trigger is released the needle raises back to 20.
    I understand that the back pressure is off once the trigger is pulled and would account for a small drop but 8 points on the scale is more than a third.
    I have turned up the the regulator so that it registers 20 while the trigger is on and not noticed any change in the weld.
    So have any of you investigated this situation.
    Cheers for any comment.
    Cave Creek Az
    1,069
    Best thing to do is get one of these. http://weldingdirect.com/gasflowchecker.html It will give you the truth of the matter at the business end of the machine and take away the guess work. Otherwise, start high and turn it down until you start geting porosity, then turn it up a bit.
    Aug 2010
    1,179
    X2 what Walker said.
    Verify what is really coming out at the nozzle. 8 points is more than I have ever heard.
    Miller Dynasty700DX
    3 ea. Miller Dynasty350DX
    Miller Dynasty200DX
    ThermalArc 400 GTSW
    MillerMatic350P
    MillerMatic200 with spoolgun
    MKCobraMig260
    Lincoln SP-170T
    Linde UCC305 (sold 2011)
    Hypertherm 1250
    Hypertherm 800
    PlasmaCam CNC cutter
    Fadal Toolroom CNC Mill
    SiberHegner CNC Mill
    2 ea. Bridgeport
    LeBlond 15" Lathe
    Haberle 18" Cold Saw
    Doringer 14" Cold Saw
    Wa
    657
    Mine only drops 3 or so. 8 seems like something is wrong.
