Results 1 to 3 of 3
    Apr 2013
    Default syncrowave 300 low weld output
    I am trying to repair a syncrowave 300 which has very low weld output (will not melt stick electrode). I have tried this machine with various settings (hi/low, AC/DC, with panel or remote control) and always the same thing. However when using the start current I can get plenty of power out, so the main power components are probably ok. I am guessing it is something in the regulation circuit and already tried swapping PC1, PC2 & CR1 from a working machine. Also the hall effect is giving a proper voltage signal representing the output current.
    I am out of ideas here, any suggestions?
    Apr 2013
    any help would be much appreciated
    Sep 2012
    3
    Quote Originally Posted by noloafing View Post
    How do u check the hall effect and output current? i have a problem with mine it runs wide open!!!
Tags for this Thread
