Results 1 to 10 of 14
Thread: tungsten
    Sep 2011
    3
    Default tungsten
    Hi all, I have recently purchased a syncrwave 200 and was wondering which tungsten (color) would best suit this machine for welding aluminum?
    Aug 2010
    Los Angeles
    1,163
    Easiest to find is orange(ceriated).
    Check pricing here. http://www.usaweld.com/Tungsten-s/59.htm
    Miller Dynasty700DX
    3 ea. Miller Dynasty350DX
    Miller Dynasty200DX
    ThermalArc 400 GTSW
    MillerMatic350P
    MillerMatic200 with spoolgun
    MKCobraMig260
    Lincoln SP-170T
    Linde UCC305 (sold 2011)
    Hypertherm 1250
    Hypertherm 800
    PlasmaCam CNC cutter
    Fadal Toolroom CNC Mill
    SiberHegner CNC Mill
    2 ea. Bridgeport
    LeBlond 15" Lathe
    Haberle 18" Cold Saw
    Doringer 14" Cold Saw
    Pure
    I use 2% red for everything. I have some pure green stripe that I use for small guage aluminum, but if I'm welding over 120 amps, I use the red. I have a sync 200 also and I mostly weld heavy stainless with large valves.jpgthe machine at 160-200 amps
    Feb 2012
    NY
    98
    Red, green and orange all have there place for that machine as far as bead profile is concerned. Balling effects etc. with amperage and material thickness, esp with aluminum.
    Oct 2009
    305
    Pure (green) tungsten is not recommended with a square wave machine on AC. use ceriated (orange)
    and wp2025 weldcraft torch
    Miller 125c plasma cutter
    Jul 2010
    375
    2% lanthanated for everything
    Try ebay for good prices
    Jul 2008
    Flin Flon & Creighton area
    232
    Quote Originally Posted by Helios View Post
    +1 for what he said ^^^^^
    I have a welding addiction
    ...the only stupid question is the one you didn't ask
    Default tungsten
    Try the purple tungsten for that machine they hold there tip amazingly well the same if not better than 2% LAN.
    Sep 2012
    seaford de
    406
    Quote Originally Posted by jrscgsr:306975
    Why is that? And where did you get this from? I have used and still do use pure with my lincoln square wave and it works great... i use ceriated on thin alu. Under 3/16. Anything over i use pure
