    Default Wasp won't sting ! please help !
    Hi all just joined after reading some of the great info here by those that know allot more than me ! My machine sat all winter and when I fired it up a couple weeks ago no output ! It is a 1967 Airco Wasp {made by Miller** Mod. 2.25A/AMEL-A ser#R395785 . I took the shroud off and cleaned a bunch of contacts etc. still nothing ,All the leed connectors have been cleaned and I have tryed every thing right back to the tails directly off the front pannle . I have DC power to the aux outlet but no AC power on the side outlets ? I have not tried ac weld output because I need DC ! I have not looked at the back side of the buss bar board because from what I can see that is all good I cleaned the contacts for the switch . This machine seems simple enough everything is real basic but I just cant figure it out ! I also cleaned the copper rings that the brushes ride on and did find one of the side by side smaller brushes was stuck so I freed that up . I also emoried the back side of the amp adjuster dial but that looked good anyway . I don't own a tester but can get one if need be . I have the manual and think I understand what parts are what ,but any sugestions please be descriptive in were I am looking . Thank you in advance for any help ! I desperatly need my machine to work !
    Dec 2010
    Andover, Ohio
    106
    Welcome to the forum.
    Apr 2013
    Southeast idaho
    30
    How sure of your ground are you?
    Aug 2008
    Orange, TX
    1,215
    Check for corrosion at the field current trim resistor tap strap.
    Not uncommon for rust build-up to cause loss of continuity at this point resulting in no field voltage getting to weld/power rotor.
    Syncrowave 180 SD
    *HF-251D-1
    *WC-1S & Spoolmatic 1
    PakMaster 100XL
    Marquette "Star Jet" 21-110
    Hooooyaahhhh I got ark ! Went out this morning and took a long hard look at all my conections cleaned a bunch of spade connectors etc took my time and even made a new ground lead etc . cranked her up and made blue light ! I have never not had my machine and was worried sick that it was done ,but once again it has pulled through for me ! So today I'm gonna be burnnin some low hi in the sun ! Thanks to those who responded ! You gave me some direction to look and I think it must have payed off ! I would like to stick around here for a while .I see a bunch of topics that interest me ! Talk soon guys !
