Results 1 to 10 of 11
    Default Clear Coat - Mild Steel
    Have a little art project for class made of mild steel and mig'd. I'd like to coat it in something if possible that will prevent it from rusting and keep the shine after I polish it.
    Is there something I can get from a place like Lowes and spray on it that will do this?
    Miller 211 MVP
    Hobart StickMate LX 235
    Lincoln AC 225
    CutMaster 42
    Apr 2013
    7
    A hot dip galvinizing layer will prevent most atmospheric corrosion. You may need to look around but it shoud be in the hardware store. This will create a neat design in the piece though. Good luck.
    Jobe
    Default clear coat
    I would use the old yellow label ppg clear it works great for what you are describing. It's a acrilic type of clear coat you don't see it much anymore
    ARMOR
    MOBILE WELDING&SERVICES
    Trailblazer 302
    X-TREME 12VS
    Spoolmatic 30A
    Millermatic 135
    WeldCraft WPseries TIG torch
    Smith oxy set.
    Oct 2005
    North Central Indiana
    782
    Jun 2009
    greenfield new hampshire
    884
    spray can of laquer
    Feb 2010
    YOUNGSTOWN, OHIO
    172
    Default clear
    Go to the local home improvement store and get a spray can of polyurethane or lacquer.
    JIM
    Millermatic 350P Aluma Pro
    Maxstar 150 STL
    Trailblazer 302
    Suitecase 12RC
    Extreme 12VS
    Extreme 8VS
    Spoolmatic 30A
    Miller HF251D-1
    Passport Plus
    Spoolmate 100
    Hypertherm Powermax 45 and 85
    Dake 75 ton H-Frame Press
    JD Squared Model 32 Bender
    Miller Digital Elite
    Boise, ID
    36
    Krylon Clear gloss or Clear satin works great. Just make sure all water and oil is off steel (wipe down with acetone). Spray lite coats 20 - 30 minutes apart. Make sure you get all the cracks and clevis's are covered.
    Good luck.
    Wa
    628
    Deft
    You folks are awesome. Thanks.
    Miller 211 MVP
    Lincoln AC 225
    CutMaster 42
    Cave Creek Az
    1,046
    Just so you are aware, spray can clear coats are great, and dry fast, but are a little fragile, so handle with care or it will scratch off. Also nee to wipe down with thinner before spraying o it will stick.
    Perma-Lac, and Clear Guard from Sculpt nouveau and better by far, and are available in a spray can, more expensive, and you have to wait for the brown truck to bring them
