Page 2 of 5 FirstFirst 12345 LastLast
Results 11 to 20 of 46
    Oct 2005
    North Central Indiana
    783
    Amazon had theses on sale for about $35 dollars, they came with 5 or 6 grinding
    wheels and the case. It's not a high amp motor but I'm going to use it for slicer wheels.
    Spare 5" rat tail, I was going to put a 6" wire wheel on it but never did.
    Dec 2012
    Simcoe Ontario
    108
    Default metabo cust. service
    You mean metabos don't have that nice heated housing and burnt plastic scented feature that activates after using it for a couple hours like the dewalts and most others? That's a shame. How do you prove you've been actually grinding ?
    Sep 2012
    seaford de
    407
    Quote Originally Posted by tackit:306761
    I also bought this same thing from Lowes. It was around the same price. And I also have a 7" Hitachi. I think I got the 7" from tractor supply... I don't use a 7" or a 4 1/2 very much, I use my 6" mostly
  4. #14
    Sep 2012
    seaford de
    407
    Quote Originally Posted by Nathan128:306763
    I don't. You can take it or leave it. Simple as that.
  5. #15
    Sep 2012
    seaford de
    407
    Quote Originally Posted by Sberry:306753
    I see,,, ok,, how about this, learn to be a bit better welder and you wont have to be such a grinder.
    I will have to do that.. I learn something new everyday but will that save my grinders from being used? I do lots of dump truck floors, steel and aluminum. And my helpers mostly do the grinding, their learning just like everyone else. In my world you do your grinding before you weld so I don't think it will help but maybe you know something I don't....?
  6. #16
    4,502
    In a 6 inch the aspects of the particular models may be different. I am no stranger to burnt up Dewalt grinders, B&D before that. I liked the feel of them when I was using them a lot. They souped up the current numbers on them, put them in the same chassis and if you ran them like you were mad at it poof, pretty easy to overheat and a hundred bucks out the window and I know its tuff to swallow but would 2 or 3x rather have the cord that comes on the cheap version.
    I have never overheated a Walmart one, its got good power. Pick one up sometime feel how heavy it is. I gave a couple away, I put one dedicated to the bench where the use was quite high just to see how long it would last, it finally gave out a switch after it outwear a Dewalt about 3 to 1. And after about 3secondsfs never give it second thought there is 100 difference in price.
  7. #17
    4,502
    I know you are a pro.
  8. #18
    Sep 2012
    seaford de
    407
    Quote Originally Posted by Sberry:306785
    I do like the dewalt 12 amp 4 1/2". I have a few of them in a box that someday when I get the time they will make one good one. I also use the dewalt portaband... It has held up well, only thing I've done to that is change the gear oil and blades
  9. #19
    Oct 2005
    783
    6" is my favorite grinder too. I like the balance rat tails give, to me they don't tire the hands as much as a barrel grinders do, must be the rat tail handles are thinner making them more comfortable to hold.
  10. #20
    Salem ,Ohio
    3,972
    Cool
    We have over 350 Metalbo's at work. They are like the rest of them they wear out. I have been there just over a year and have had 5 new ones and a few rebuilts. But this shop requires every weld to be ground or wire brushed smooth and zero splatter anywhere so they take a beating, prob better than any other brand...Bob
