Page 1 of 5 12345 LastLast
Results 1 to 10 of 46
    Sep 2012
    seaford de
    406
    Default metabo cust. service
    I bought my 10th or so metabo grinder, probly my 5th or 6th 6in about a month ago. A week into using it the switch stuck on, I got it to free up after messing with it for 10 minutes or so. After that I didn't do anything but use it until yesterday it wouldn't turn on at all no matter how much I tried. After messing with it I seen that the plastic was broken under the switch so it was useless. I called the lws where I bought it and they said they would have to send it off... and as some of you know I can be a **** about things and I'm not paying 250 for a grinder just to have a repaired grinder a month later.. so I called metabo service/warranty dept. And they said they would replace it without question and if my lws had a problem with it then they could call metabo themselves. So bottom line is I will be sticking with metabo for a long time, great customer service and great products... a lot like miller, you pay a little more but in the end it pays off
    Illinois
    611
    I still have my first METABO 4 1/2'' that I bought 30 years ago. It just won't die.
    Sep 2012
    seaford de
    406
    Quote Originally Posted by BD1:306653
    I still have every one I have ever bought but the brushes are gone out of them. I guess its all in how much you use them. While I was on the phone with metabo I asked about sending them to get rebuilt and its pretty reasonable on price. I'm going to send a few in.. they said the turnaround time is 48hrs, not too bad.
    4,432
    I want to make sure I get this right before I spend on a new grinder.
    I have been down the grinder road a good long time, about the best grinders I have used is the 30$ Black and Decker from Walmart, everything about it lasts, right down to the brushes and the cords. Pick it up and use it and cant tell it from any other. You would have 8 grinders that still worked for the price of one. Not every cheap grinder or tool is good but this one is.
    Sep 2012
    seaford de
    406
    Quote Originally Posted by Sberry:306685
    I left out all the dewalts, milwaukees, porter cables and cheap ones i ever bought. I have thrown most of them away but still have a BOX of useless ones. As in broke, not fixable like the metabos that i bought within the last 15yrs. If you read what u quoted. It say's ''im not paying 250 to have a REPAIRED grinder a MONTH later. Not 15yrs later. I can burn a black and decker in a day or two.... junk... worthless... been there done it. And if you try to call black and decker and get customer service their probly gona ask.. whats that. Their plant used to be a couple miles away from me but now nobody speaka alglashe.
    Sep 2012
    seaford de
    406
    Sberry... the reason your grinders last so long is because your not using them.. your spending your time on here picking apart a simple little post.
    Used Metabo drills for many years in electrical construction. Never die is right. Things were beasts.
    Miller 211 MVP
    Hobart StickMate LX 235
    Lincoln AC 225
    CutMaster 42
    4,432
    I see,,, ok,, how about this, learn to be a bit better welder and you wont have to be such a grinder.
    Oct 2005
    North Central Indiana
    782
    MY favorite grinders are Hitachi... but my favorite die grinder is a Matabo GE 700 6.2 amp Variable speed die grinder. It's been a great tool and has got me out of trouble more than a few times, from removing welds in tight places to enlongating holes so bolts pass through, to putting in an arbor and installing a 3" Weld Eraser Wheel on the end to cut tubing and removing welds. Yes I would recommend one to a friend.
    Oct 2005
    782
    Here's my grinders, Bosch, Hitachi, Makita, The 5" Hitachi and 6" Makita rat tail handles are my favorite. I run 6" wheels on the 5" Hitachi rat tail.
