Results 1 to 4 of 4
    Apr 2013
    9
    Default Weld shield walls/curtains?
    I have a rather cramped garage, so I want to put up some sort of wall or curtain around where I will be using the MIG. Not much of a clue as to what material I should use -- suggestions?
    WY...armpit of U.S.A.
    659
    If you go with a wall, a simple stud wall in either wood or metal studs with a sheetrock covering should be more than sufficient. Remember to tape and mud the joints. If you feel you need more, hardie panels, hardieboard, whatever trade name it goes by in your region.
    If on the other hand you wish to go with curtains, try here...
    http://www.google.com/search?safe=ac...L8nRiALL44HgCA
    Miller DialArc 250
    Lincoln PrecisionTig 275
    Hypertherm 900 plasma cutter
    Jet 14 X 40 lathe...ditto
    Logan 7" shaper
    Ellis 3000 band saw
    Lots of dust bunnies
    Oct 2005
    North Central Indiana
    782
    You also could mig a small 6' X 6' or what ever size you need frame made of old steel bed frames or sq tubing...mount caster wheels on it and use metal building siding to sheet it.
    Feb 2012
    Wa
    557
    Harbor freight sells welding blankets dirt cheap. They hold up ok, but are cheap enough to replace once they wear.
