    1,890
    Default Chipper & skidder
    I did maintenence work on a track chipper. Basically repair any cracks I find, build up knife pockets & chute behind the pockets. I just try to do the welds on each pocket an even amount to keep it balanced. I haven't had a problem in the past. This time I had to build up inside the disc housing. I just went in as deep as I could reach. Next time we may have to pull the disc out.0423031302.jpg0423031303.jpg0423031258.jpg0423031259.jpg0423031300.jpg
    1,890
    Here is the skidder blade that I started on. It's just hanging from the skid steer here. Got it cut apart & cleaned up. Mainly just the edge area, not to bad once all the bad stuff is removed. More pics soon. Going back today.0424031358.jpg0424031401.jpg
    Aug 2004
    Milan Michigan
    1,793
    I just love seeing worn out equipment, I see 100.00 $$$$$ signs when I do.
    1,890
    Here is the finished pics. Didn't get to take any till I was leaving. I wanted to get some better ones but as soon as I was done they had me doing some other stuff while they put it back on the skidder. Customer is happy. 1" x 6" hot rolled flatbar for the edge & the bottom. The old pcs. were 3/4" flat bar over the original edge & they lasted some 15 yrs. so these should last a long time.
