    Default TIG setup on a Lincoln AC225
    Can I run the old school TIG welding setup without high frequency on this? It's AC only.
    Sep 2012
    seaford de
    406
    Not without hf box. You need dc to tig weld
    Nov 2012
    Northern Arizona
    537
    You need a hf box or you can build a rectifier. It will then be a scratch start setup. Ideally you can setup a on/off type switch so you can keep your shielding gas around the end of the weld and stil stop the arc without leaving a crater. A little Google on homemade rectifier should get you a good start
    MillerMatic 251
    Maxstar 150 STH
    Cutmaster 42
    Victor Journeyman OA
    Sep 2012
    seaford de
    406
    The old school way of welding aluminum if that's what you mean... was DC welding on elec positive. The tungsten burns back quickly but actually welds pretty good. And I guess the ac DC version of that machine is just a added rectifier? So maybe that would work but if it were me I would sell the ac unit and buy something like a old econo tig. That way ya got it all
