Results 1 to 7 of 7
    Oct 2005
    North Central Indiana
    782
    Default My hobby version of a homemade sheet metal bender
    Built back in 2008, I used Lincoln's version of Missile rod to weld the cut-off cast steel C clamps to the frame. I used 3X2 angle for the bending bar so I could bend past 90 degrees to allow for spring back. I haven't used it a lot, but it don't eat and parks out of the way. Thanks for looking.
    The test bends were 16 ga
    http://s1298.photobucket.com/user/cy...Metal%20Bender
    Sep 2009
    Colorado
    230
    Default Photo is private.
    I tried to look at the photo, but it said that the photo was private, so I did not get to see it.
    Richard
    Oct 2005
    782
    Sorry, try it now raferguson.
    Sep 2008
    Dalton, GA
    132
    Nice bender. I made one similar but not nearly as nice.
    The stand is a good idea.
    Burt
    _______________________
    Miller 211AS
    Miller 375
    Miller Syncrowave 250
    Miller Thunderbolt XL
    http://www.10FtDrillBit.com
    Sep 2009
    Colorado
    230
    Default Material?
    Looking at the photos, I am a bit confused. It looks like the moving part is channel, but you say the bender bar is 2 by 3 inch angle. Or is the 2 by 3 angle the hold down?
    Also, it looks like the pivot point is above the plane of the table, but maybe that is not so.....
    It looks good overall.
    Richard
    Oct 2005
    782
    Thanks guys, there is always a better way to do to do something.
    raferguson, the picture makes the bolt look higher than the top of the channel iron but it's not. From the bottom of the flange to the top of the channel I'm guessing is close to two inches.
    http://i1298.photobucket.com/albums/...1366762022?768
    You're right, I'm talking about the 2X3 angle that holds the sheet metal down.
    Oct 2005
    782
    Quote Originally Posted by iaho888 View Post
    Nice pics these pics show that some hard working is done on it which is owner for the maker..How much time is to make this one metal blender?My hobby is to collect the pics and save it into the file and after that research on it...
    iaho I took my time building it, I worked a little bit on it each day. Just guessing I would say two days. It still needs a 1/2" rod bent in the shape of bicycle handlebars that can be flipped down to stand on and way to lock the bending arm in a horizontal position for transporting it.
    What I do now to move it around is put a plate under the 2X3 angle (the angle that the c clamps hold down] and let the plate stick out past the channel iron frame so when I raise the bending arm with the pipe handles the bending arm hits the plate on the way up.
