Results 1 to 7 of 7
    Nov 2012
    Northern Arizona
    528
    Default Diesel Fuel Transfer Tank
    I need to build a disel fuel tank that will go in the back of a polaris ranger 6x6 utv. I've got everything squared away except for the 2" threaded bungs for the transfer pump and filler/vent cap. Do you guys have a good source for these? I am going to build out of mild steel. Aluminum would be nice, but it won't last with how it is going to be used. It is too easy to pop a hole in it. For a drain port I am looking at just using a 3/4" pipe coupler and plug. Should end up around 90-100 gallons of usuable capacity.
    Thanks.
    MillerMatic 251
    Maxstar 150 STH
    Cutmaster 42
    Victor Journeyman OA
    Dec 2008
    shawnee ks.
    22
    Elvis try a hydraulic supply house that makes hoses and has fittings a Tomkins or a Fastenal . good luck chris
    May 2012
    27
    Elvis go to a electrical supply house and ask for a 2" pipe fitting. That is what i use when i make tanks for local guys here in florida. They also make them out of aluminum. Good luck
    May 2011
    Bossier Parish La.
    550
    Since your building it with steel, all you need is standard 2" threaded pipe for the bung and a 2" pipe cap with a small hole less than 1/8" drilled in it. That's what all the transfer pumps have for threads anyhow. No need to overthink or over pay for what you need. Use 2 of them so you can have a filler neck and a bung to install the transfer pump. You don't want to have to remove the filler cap, install the pump, transfer fuel, disconnect the pump and put the cap back on every time you refuel something. This way the pump stays mounted and you have a separate place to fill the tank. The large bung opening in a 55gal. barrel is 2" standard pipe thread, the small one is 3/4".
    On the drain bung, you should consider a ball valve with a plug in it rather than the plug alone. If you ever need to drain it, and remove the plug, the fuel is going to go everywhere. With the valve on there you can connect a hose and direct it where you want it before opening the valve.
    Oct 2009
    Northern ND
    17
    1,883
    I like to use sch 80 half couplings for bungs. Just a little thicker than sch 40.
    Nov 2012
    Northern Arizona
    528
    Thanks guys. Schedule 80 couplers it is.
    MillerMatic 251
    Maxstar 150 STH
    Cutmaster 42
