Results 1 to 2 of 2
Thread: thin 304 ss
    Apr 2013
    Default thin 304 ss
    hello, i need to weld a 0.012" to a 0.090" 304 stainless at a 90 degree. I am using a 040 tungsten and a 030 filler. what would be a good set up on a dynasty 200dx? I have already set the machine for the 040 tungsten. thanks for your help
    Aug 2010
    1,176
    Quote Originally Posted by thinvince View Post
    Is that inside fillet or outside?
    Outside fillet I would enable the default pulse settings. Inside I would not to try to keep the arc tight. I would start at about 40 amps DC. Outside use a gas lense perhaps #6 nozzle, inside conventional #4 to #6 straight nozzle.
    Miller Dynasty700DX
    3 ea. Miller Dynasty350DX
    Miller Dynasty200DX
    ThermalArc 400 GTSW
    MillerMatic350P
    MillerMatic200 with spoolgun
    MKCobraMig260
    Lincoln SP-170T
    Linde UCC305 (sold 2011)
    Hypertherm 1250
    Hypertherm 800
    PlasmaCam CNC cutter
    Fadal Toolroom CNC Mill
    SiberHegner CNC Mill
    2 ea. Bridgeport
    LeBlond 15" Lathe
    Haberle 18" Cold Saw
    Doringer 14" Cold Saw
