Results 1 to 3 of 3
    Oct 2005
    North Central Indiana
    782
    Default I needed a sod cutter so I brought out the plasma and the MM180
    If you should need to make a handle a 1" EMT conduit is a perfect drive on fit over a 3/4" BP nipple.
    I beveled the 3/4" nipple's edge, laid the blade down on the welding table with the 3/4" angle iron flange looking down and could only drive the 1" EMT on the nipple about two inches with my 8 lb sledge. It didn't need to be welded or bolted on the handle fits so tight. I think what stopped it from going on farther is the shaved galvo on the inside caking up.
    Dec 2012
    Front Royal, Va
    64
    Looks real nice. Always nice to save money and having made something you can use........Fireman Bill
    Oct 2005
    782
    Thanks Fireman Bill, it's simple but a good project for guys just starting to weld.
