Thread: warping steel
    Jan 2013
    20
    Default warping steel
    I've got a problem with a part we are trying to make.
    It's long thin steel with some nuts welded on it.
    I have a tolerance of 0.5mm.
    And as soon as I take it out of the gig it's over 1 mm out. And it's execentuated down the piece.
    I've tried welding it as cold as pos, doing one small weld at a time with cooling in between.
    Any ideas?
    Oct 2009
    306
    Pre camber the part by placing something under the middle and clamping both ends before you weld it. Might take a part or two to nail it.
    and wp2025 weldcraft torch
    Miller 125c plasma cutter
    Cave Creek Az
    1,067
    Ditto, if you are a MM out, try starting with a mm camber the opposite way and you should come out straight. Helps if you can let a cool a minute or two before taking out of the jig
    Oct 2005
    North Central Indiana
    782
    What kind of metal, how long is the work piece, what welding process are you using, how many welds and how close together are they?
    Is a product like this large and strong enough to use for your project. I have used my rivet nut set a few times, for my applications they worked fine.
    http://www.rivetsonline.com/rivet-to...ith-tools.html
    Could also try pre heating the piece before you start welding.
    Sep 2012
    seaford de
    407
    Try this stuff. It really does work well on all metals. On the back of the tube says... keeps adjoining metals from distortion, discoloration, warping, cracking, buckling, or blistering caused by welding, brazing or soldering.
    Jun 2009
    greenfield new hampshire
    889
    yep, got a few tubes hanging around, miracle stuff
