    Feb 2013
    6
    Default millermatic 35 no wire feed
    I have a millermatic 35 it stopped feeding today after doing several welds. It appears that the drive motor has stopped working. Just wonder if anyone has had this problem and what to look for. thank you
    Nov 2012
    Indianapolis
    3
    Default wire feed problem
    Its could be the motor is bad or your trigger wire is shorted or you could have the drive rolls too tight I work a at repair shop and alot of times on those little millermatic the fan motor goes bad under warranty?
    Nov 2012
    Indianapolis
    3
    Never mind about the fan motor I was thinking of those little 110/230 millermatic sorry
    Could be the liner. Mine done that before and the liner was stopped up
