Results 1 to 9 of 9
Hybrid View
    Apr 2013
    4
    Default Millermatic 140 problem
    First off, i'll introduce myself. My name is Terry, i live in Eden NY. I work on our family dairy farm and in my spare time i'm either working on motorcyles or out riding.
    Now onto the issue i'm having. I've owned my millermatic 140 for 6 years now and it has worked flawlessly up until last summer. When you start the weld, it acts as though it is not hot enough, you can feel the wire hitting the material. once you get a puddle it will weld just fine. it only does this once in a while, but has been acting up more recently. i checked my ground and ground connections, everything is clean. to rule out a feed problem, i hooked up my spool gun. welded great on the scrap piece i tried, then went to weld the project i was working on and it did the same thing, like its not getting hot enough on the start.
    Anbody have any suggestions?
    Feb 2012
    Wa
    656
    Is the work piece clean and rust free? If it works fine on one piece of metal and not on another I would suspect that.
    Nov 2012
    Northern Arizona
    553
    Blow out the mig gun liner. Clean the contact tip or replace it. Also, might want to see if there is some corrosion on the wire. What wire/gas combo are you running? Might be worthwhile to get one of those little pads that cleans and lubes the wire right before it goes into the drive rolls.
    MillerMatic 251
    Maxstar 150 STH
    Cutmaster 42
    Victor Journeyman OA
    Apr 2013
    4
    yeah, everything is clean and rust free. it will weld fine one minute and not the next on the same piece. i changed tips and cleaned liner, one of the first things i tried. to rule out a liner issue or wire feed motor issue, i put my spool gun on and it does the same thing.
    Nov 2012
    Northern Arizona
    553
    I would try and clean the work area and ground point with a grinder. And then wipe down with acetone prior to weld.
    Wire? Gas? Do you have a stamped steel crap ground clamp or a brass/copper clamp? Have you checked the lug tightness of the whip and ground connector?
    MillerMatic 251
    Maxstar 150 STH
    Cutmaster 42
    Apr 2013
    4
    it's not a ground issue, went through all that when it started acting up, checked all grounds, new good clamp. ground area on piece is always clean. any other ideas what to look for?
